Seized wheel spacer
98gsCamB
4
Dec 12, 2021
Pasadena, Maryland
Does anyone know how to get a wheel spacers that is seized off without the use of some wonky tool?
Did you try hitting it with a hammer? maybe include a pic so we have a better idea of what you are up against?
I tried a rubber mallet all the way around tried to chisel it too after using some pb blast gona try a heat gun when i get home and ill post a picture then
Exactly what im currently doing, already put a ton of pb blast on it gona be back home ina hour to give it some heat
That combo worked perfectly with a big hammer got all of them off no problem after that!
BFH and a chisel, go to town. You’re not reusing it. It should come off easily.
BFH Worked great didnt even need the chisel
