- Ownership Status
- Currently Own
- Year
- 1995
- Model/Trim
- Eagle Talon TSi
- Turbo Type
- HX40
- Drivetrain
- AWD
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- Intake: HX40 7 blade - VRSF FMIC Kit - Turbosmart Dual Port BOV - "Cyclone" Variable Runner Intake Manifold
Exhaust: Morrison Fabrications T/S Compact T3 w/ 3" SS Hot Parts Kit - Dual Tial MVS (25 psi springs) - DIY SS 3" cat-back - Varex VMK5-300 electronic cutout muffler
Fuel: FIC 1650cc Hi-z - Aeromotive 13301 FPR - 8AN Tank-to-Rail - Walbro 535lph - Billet EVO III Fuel Rail
Cooling: 1g model Mishimoto X-Line radiator, 2x Spal 12" paddle blade push fans, Evospec underdrive water pump pulley
Other: D51R (26 lbs) battery - OBX 6.5qt baffled oil pan w/ 1" return
- Mods-Engine
- 2.3L Eagle/Wiseco 9:1, 6 bolt - Kiggly Beehive Street Springs - Kiggly HLA - Kelford K264s - AEM TruTime Cam Gears (evo model) - ARP L19 Head Studs - Mitsu MLS HG - Fluidampr Crank Damper
- Mods-EMS & Logging
- ECMlink V3 - Zeitronix ZT-2 WBO2 - Omni Power 4 Bar Map Sensor - GM IAT - GM Ethanol Content Sensor - IR BCS - RPi 3b+ OpenAuto Pro w/ 8" multi-touch - Autometer Carbon Fiber Ultralite: Oil Pressure & Boost - Autometer 2246 Pressure Transducer (Fuel) - Defi ZD Display
- Mods-Drivetrain
- Built Transfer Case by TMZ: Boostin Performance 300M Output Shaft, Boostin Performance billet mid-housing, Frontline Fabrication full-length billet brace
BROKEN Evo-II Transmission by TMZ: Boostin Performance Transmission Output Shaft, Kaaz Super Q Front Differential, TMZ 4-Spider Center Differential with Beyond Redline Cross Shaft, spare neutral 4th gear mod.
DSS 3.5" Aluminum Driveshaft - Graveyard Motorsports Rear Axles - Comp Clutch 2-735-1ST Flywheel - SBC K536SSXTZ/B Clutch - ThreeSpeed Scatter Shield
Solid Aluminum: Front Subframe Bushings, Driveshaft Support Bushings, Rear Subframe Bushings, Rear Differential Bushings, Shifter Plate Bushings, Shifter Bracket-to-Trans Bushings, and Shift Cable Bushings, Front Engine Roll Stop.
Solid Polyurethane (black_gst) Rear Roll Stop - Prothane Polyurethane Side Engine and Transmission Mounts
- Mods-Handling
- JIC FLT-A2 coilovers - Enkei TFR 17x9 +40 - 235-45r17 Goodyear Eagle F1 RSA - china strut bars - Prothane Suspension Bushings - Volk Rear Toe Arms - Volk Front LCAs - RM Rear Sway Bar - 1st GEN CTS-V Front Brembo Calipers - 03 Cobra 13" Front D/S Rotors - Evo VIII Rear Brembo Calipers - D/S Evo VIII Rotors - Akebono Street Performance Pads F&R - 3g Eclipse Brake Master Cylinder - Pruis Electric Power Steering Column Unit - Variable Assistance Electric Power Steering Controller
- Parts Wishlist
- Better tires, also need to add lightness!
- Background
- Plan is to drive the car around. Goal is to not need a tow home.
