Route of non turbo and turbo rear o2 sensor
shaunp
115
4
Mar 11, 2008
Snellville, Georgia
I wanted to know if the rear o2 sensor on a non turbo car follow the same route as a turbo model? Can someone let me know if this plug connects to the rear o2 sensor?
This is for a 2g
Thanks
On my non turbo gs spyder the rear o2 sensor follows the exhaust, comes up by the axle and has the harness connector right by the ac compressor. Then it has a harness extension from there to the top of the manifold where the other connector is clipped on to a bracket right the crank position sensor and the vacuum solenoid. My connector is different from the turbo's rear o2 sensor. My connector is the same as the front.
Btw, the rear o2 harness goes through the body on the turbo and that should be the connector for it in your pic
Go to sparkplugs.com and it will show you a picture of the connector.
