Non Turbo exhaust
Sparkplug90
Mar 8, 2012
Clarksville, Tennessee
i wanna get a new exhaust manafold...mine has a crack....and im also looking at eventualy making this a turboed car...but everything im finind i cant find any instructions on how to add a blow off valve to my non turbo exhaust system... im assuming that someone here has already don that.
Please help
The blow off valve goes on the intercooler, not the exhaust system, and a turbo manifold is completely different from a non turbo one, so when you turbo your car you will have to buy another one, if I remember correctly there is nobody that makes any kind of adapters to use the same manifold. Its either one or the other.
I understandthat both the turbo header and the non turbo header are differnt..i can see taht..waht im asking is when i put the nonturbo exhaust manafold on my car, where do i add the blow off vaulve since normaly it is attached to the manfold. The reason i am asking is becasue i dont see anywhere where there is a nonturbo exhaust system with a blowoff vaulve attached to it
Becasue i was always under the impretion that the blowoff valve/Waste gate were the samwe thing..but now i see tehy are different.
Please put more than 5 seconds of thought into typing out your posts. Grammar and punctuation are key to being taken seriously and not giving the rest of us migraines.
You have no need for a blow off valve, which would be located on the intake side of the engine. It is for evacuating the charge pipes when you close the throttle.
Nor do you need a wastegate, which allows exhaust gas exiting the engine to by-pass the turbine wheel in order to limit boost pressure.
If you will be turbocharging your NA car in the future, save your money on a worthless NA header and put it towards your turbo build.
As in: if you insist on buying a manifold and a wastegate, but them to fit whatever turbo you plan on using.
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 2g 2G 7 Bolt Cylinder Head
    2G 7 Bolt Cylinder Head $250 + shipping & paypal fees* deck surface measured measured at 5.20...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
