Dr Vic
- 107
- 1
- Aug 30, 2007
Dallas,
Texas
Hi Guys,
I have a couple of questions.
1. I just installed a rebuilt long block in my car. Im just about ready to start the car but since I didn't rebuild the engine myself, I decided to look at the valve train and recheck the timing. I believe I have a few loose rocker arms. I tried twisting each rocker arm and some of them make this clicking sound upon twisting and some of them don't. Those that I think are loose just twist a little. There's only about a quart of oil in the car from priming the oil pump. Ive read this post and I,m wondering what others thought of this.
http://www.dsmtuners.com/forums/new...d-rocker-arms-loose-something-w-pictures.html
2. when I turn the crank using a breaker bar it just feels tight. At some points it feels even tighter. However it doesn't come to a point where I cant turn the crank. The timing marks are all lined up so Im hoping this doesn't mean that the valves will come into contact with the pistons. what do you guys make of this?
3. where does this connector go? Ive attached a pic.
4. Is it a good idea to start the car with the timing covers off? I just thought it would be better since I would be able to see everything plus check the timing before and after starting.
