Lifter, Rocker Arm ?
You can just put the lifters in but if your pulling off the head anyways you might as well do a head rebuild as long as you can afford it otherwise you can just put the lifters in. You should take it to a machine shop to do it though.
haha already doing a whole engine rebuild..
1000 bucks at the machine shop i gotta pay for the all the machine work..
:thumb: one step ahead..
So i can put the lifters and rocker arms right in?..
do i need 3g rocker arms? or can i use 2g
Make sure to soak the lifters in oil for a couple of hours. and then bleed them with a tiny allen wrench or something similar. there is a vfaq on how to do it. it's fairly easy but very important to bleed them so you don't bend the valves.
