knochgoon24
DSM Wiseman
- 6,135
- 98
- Jan 29, 2008
Troy,
Michigan
Where to start... (sorry for the essay, it's a DSM with more than it's share of problems right now.)
Symptoms:
-Can't hear turbo spool, (and i do know what it sounds like)
-Hesitates between 2k-3k when accelerating (really bad until it warms up, then it's just bad)
-I think i smelled gas while it was running a few days ago. It was brief but strong.
-There's a strong smell of burning rubber when it gets hot (been there for 4 weeks). Comes stronger around passenger side of engine.
-The check engine light is on. It usually is on (2nd cylinder misfires, has since i bought the car) but it's only occasionally. I was going to look into fixing that this summer. When sears swapped the battery, the light stayed off for over 200 miles. Usually it trips in the first 20. I haven't had the chance to get the error code read yet. I plan on doing that this evening.
-Only one of the 2 radiator fans were running when i opened the hood. Not sure if this is a problem or not, i just haven't seen only 1 on before.
Possible places to start:
-Car has 206k miles, Engine has 60k since put in the car used (by previous owner), turbo has 30k and transmission has 50k.
-The car runs very rich. Needs tuned.
-I broke the belt that powers the altenator and the water pump (November). Had it towed (flat bed) to my aunts and put a new belt on there. Replaced the other 2 when i got home.
-I just had a new battery installed by Sears (last Wed). Car barely started when it was in then 10s. I don't have a garage to work in since i'm at college right now, so i had them put it in for me.
-I found a mouse nest on the intake manifold (yesterday), but a quick check didn't show any bare wires or chewed tubes in the area.
-When the turbo did spool, when the car was cold and the temps were below 40, the turbo would kick in, then let off, then kick in, and let off until i gave it enough gas. Then it instantly jumped to 4k.
-I broke the ABS wheel speed sensor (November) while replacing a bad wheel bearing. I just broke the plastic cover off, but the wire got nicked bad too. I cut that bad section out and spliced it, and attempted to seal the cover with silicone. The first time I didn't get a good seal and water leaked in, tripping the ABS light. The second time, I used some shrink tube and liquid electrical tape. I haven't had a problem with that since. Just not sure if i might have damaged some electrical stuff while it was shorted.
Sorry for the essay, but i have no clue where to start.
Symptoms:
