Don't know where these connectors go
combatmedic
217
Jan 27, 2010
Fountain, Colorado
So I did the 6 bolt swap and I have two wires that aren't connected. One is around where the thermostat housing is and through research I want to say its the knock sensor and the other is next to the air filter?? I will try to post pics if you need them
Yea theres like four wires by the thermostat housing and theres even more around the air filter so we need pics to help you out bud.
If you made the harness then you obviously know where they plug in. The flat end plugs into the actual CAS itself and the other two go to the two plugs back by the fuel return line and ac condensor plug. I believe they one is a triangle shape.
gotcha hey another question I am going to get a fwd flywheel today how can I tell its FWD and not AWD because im not bringing my AWD one to compare?
Is the 6 bolt and 7 bolt fwd flywheel the same size because I got one of those.
