dwb
5+ Year Contributor
- 1,601
- 1,111
- Sep 9, 2021
Broomfield,
Colorado
I've attached a data log of my commute to work this morning.
I've been experiencing lots of knock under low load, part throttle, ~2k-3k RPM, and usually open loop. In this log, knock continues into closed loop for a bit. I have to release throttle and roll back into it for knock to stop, and even then it doesn't always stop. This same behavior happens every time the engine is cold, up until either closed loop or full operating temp. Once at full operating temp I primarily see knock under higher load/RPM/throttle as expected which you can see later in the attached log.
Stock fuel system, 91 octane. Stock MAF. Mostly stock car except ECMLink and MBC. Running stock 2g timing maps on a fresh 6bolt with 2g pistons. No other changes to ECMLink from a stock 1g config. No boost leaks, no exhaust leaks. Lifters do not tick (3g revision). I do notice some extra engine vibrations around 3k RPM, which I speculate might be a very slightly bent CAM or sprocket (these CAMs came from a 1g that was rolled over/landed on top of the hood and broke one sprocket). I'll be swapping CAMs and sprockets in the upcoming week(s) to verify this speculation.
I'd appreciate it if someone could take a look at the attached log and let me know if there is something amiss that can be adjusted. I'm an ECMLink noob so please forgive me. Hopefully I've captured the pertinent fields and values.
