- Thread starter
- #101
keltalon
Supporting VIP
- 3,478
- 976
- Jun 29, 2003
Luthersville Ga, Atlanta,
Georgia
If I were you I would step up to a bigger nozzel for the Meth. Also set your CEL to come on at 2-3 degree's of knock.
Also for 880's your Global should be at -48 or -49 (which ever gets your fuel trims closer) Your taking away too much fuel globally hence the high STFT.
what do you guys think about this?
DSM Cylinder Head Rebuilds - Jacks Transmissions LLC
. J/k.
. The turbo is responsible for a power level that really caught us off guard. When you pull the head post some pics of your damage. thank. I will be getting my gasket this week
I did a compression check as well 150psi across all 4. The leak down test shows that the rings and cylinders are good just damn coolant getting in there some how. Guess that head lifts pretty good of there underboost.
