[RESOLVED] Boost Gauge Issues
dj_remy
153
May 20, 2008
Cincinnati, Ohio
This is a new one on me guys...........
Just re-tapped my boost controller into this line....
I had it tapped into the BOV line, but heard alot of no-no's about that, so replaced my BOV line with a vacuum line from auto zone, a little to big but put a worm clamp on it.
My issue is, it was working fine before, when I tapped into the "P" line, sometimes when I let off the throttle and it goes into vacuum (around -10 - -20) the needle surges up an down very rapidly, when I get on it, it stops, when I'm alomst at a stop, it stops.....
any suggestions?
btw, when the engine is off, the needle sits just below 0, so I doubt the gauge is at fault.
I have always had awesome and flawless preformance tapping my boost gauge at the fuel pressure regulator line. Between the regulator and the black solinode.
I no longer use the solinode so the line goes straight from the regulator to nipple on the intake manifold. I have ran it both ways and it always worked.
Well tapped into the FPR Line from the solenoid to the intake manifold, works great and I had some extra vac line from my BCS to my turbo intake / now capped, fit perfect and enought o fix the "p" line on intake, so thanks guys. :thumb:
