1G Rear Lower Control Arms, Anyone Make Them? Not A Camber Arms Question.
Car Cannibal
688
165
Jun 7, 2003
Chicago, Illinois
Hi, I'm almost done with a complete rear suspension upgrade and it appears as if adjustable rear lowest control arms aren't available for sale, is this accurate? I've seen threads on making them but for the sake of time and age I'd rather just buy new ones and install them. I'm interested in arms similar to the upper adjustable 3SX where there's a spherical joint and possibly adjust-ability.
I will just install the Energy Suspension bushings if nothing is available.
Thanks
If you click on the link that Steve posted at the very end you can see the tab be welded, but he made his own sway bar link
I ended up just installing Moog ball joints K9617 and Energy Suspension poly bushings in the lower arms with OEM bolts MF106123 and MF430123 nuts.
Then swapped in the 3SX upper adjustable camber arms and the rest of the rear suspension and called it a few crazy days.
