2G Shortend Rear Lower Control Arms?
GSR-VR
111
5
Oct 7, 2012
Albuquerque, New Mexico
Is there any demerit to shorten the rear lower control arms? Since I don't know much about suspension I figure I ask here. I know people will ask why I want shorter lower control arms but I prefer to keep the reason to myself. I'm not trying to come off as arrogant or unfriendly, I would just like to know if there is any problem with having a shorter control arm.:)
Less camber, axle may no longer fit, sway bar might not fit, lower motion ratio (which means you theoretically would need to change spring rates for the ideal setup) are my immediate thoughts.
Is this assuming the rear spindles are staying in the same location or are they moving inwards toward the body?
I apologize. I should have been more clear when asking the question. Everything is staying the same, except the shorter length of the lower control arm and the mounting place of said control arm to the body or subframe.
  • For sale Evo 8 steering wheel with dsm adapter welded on.
    Evo 8 wheel with welded adapter for dsm
    • 98TalonPandaTSI
