2G Rear Hatch Adjustment Help
Ven
Aug 16, 2021
Colorado
I am having problems adjusting the rear hatch on my 2g. The hatch is closing unevenly and is causing the driver side of the hatch to sit higher than the passenger side. I have tried to adjust the rubber stop but it didn’t seem to help with the unevenness. Does anyone have any suggestions on how I can go about fixing this issue?
If you can't find a strut causing the issue there are 4 hinge bolts that you can loosen up that have a little bit of play too, it's trial and error though and the hatch is fairly heavy so be careful. I wouldn't back them out completely, just loosen them, make your adjustment, then tighten them back down and see if things line up a bit better.
I also had this problem due to the struts. Or, specifically, missing one strut. Installed a new one but still had the problem because the new one was a lot stronger than the old one. They both went out soon after and now that they're matching my hatch sits level.
Thanks for the reply’s everyone! I will try removing the struts and seeing if that fixes the issue and if so I’ll order a pair of new struts. One strut does look newer than the other so that very well may be the problem. If that doesn’t help the problem I’ll try a new set of hinges.
Leaving a quick update. I replaced both struts with new ones and unfortunately that didn’t fix my problem so it looks like I’ll be attempting to adjust the hinges and most likely trying a new set of hinges with the hope that’ll fix it.
Boo. I've never tried adjusting the hinges on an Eclipse but when I tried adjusting the gullwing doors on my Autozam it sucked a lot. It was like a three person job because everything is so heavy and the force from the struts is at such an odd angle. Good luck!
It's a lot of work but to get more adjustment on the hinges you can open the holes up with a drill to give you some more "wiggle" in the direction you need to line everything up. Like I said, I had to do this to get my Carbonetics CF hatch to line up and it was still heavy af.
