420A Random Misfire on all 4 cylinders
estuardowrld
128
17
Jun 11, 2023
Southgate, California
Welp. This is my final hail Mary since i got the car it’s been having misfiring issues every-time i take the car on the freeway. I’ve changed every part i can think of.
Cam sensor
Crank sensor
Fuel filter
Spark plugs gapped at .50
Wires x2
Ignition coil x2
98 Auto ecu
Egr delete
Only thing i haven’t touched is fuel pump and injectors. Everytime i go on the free way in 4th or 5th gear the check engine light flashes and the dreaded codes come out. I don’t know if it’s a possibility but the old owner had wired in the ecu. Please help
What did the old owner “had wire”? Had wired what. What are the “dreaded codes”. What do they say?
How is the ignition power transistor? Is the connector in good shape? Is the power transistor looking good visually?
He wired the whole ecu from what i recall when i first purchased the car. But to be completely honest when i first got the car all the vacuum lines were torn up all car was running on no oil. The codes are as follows p300 P301 P302 P303 P304 P300. I haven’t tested the transistor.
Ok, those are random misfire codes. So would you say the problem only happens on the highway when the engine is under load? Is it cruising rpm? How repeatable is it? Does the car lose power?
Yeah it only happens when the car is under load everytime i take it on the freeway it’s a guarantee it’s done this 6 times already. And yeah the car loses power it feels sluggish and the shifts are rough.
With a fuel pressure gauge. There is a threaded AN fitting on the end of the fuel rail, remove the plastic cap and attach the gauge. You may only be losing pressure under load though, in which case you couldn't see it.
If the ECU wiring has been cut into I would probably start by making sure everything has continuity and good connection. If it were a wiring issue I'd assume the issue as constant but maybe there's a specific vibration frequency exposing the poor connection. You may just consider soldering the connections and adding shrink wrap. I can only imagine a bunch of exposed crimp connectors, based on things I've seen of your previous owner.
Also, why would you be running an auto ECU if the car is a manual? It should run with but there are some map differences.
Low compression would indeed cause misfire codes but again, that would be a consistent issue. The dipstick will start blowing out before the misfires though.
Hello guys to answer the questions. I mentioned the Auto ecu because it still did it with the auto ecu. I’m running the manual one and it still does it. i did a compression test all cylinders 160-170. And yes i still have a catalytic converter. Also if it is the fuel pressure how would i fix that? I will show you guys my ECU connections.
This is how my ECU currently sits i also removed my intake manifold and it’s really dirty gonna give that a clean. I also took out my injectors i’m gonna get them flowed tested and rebuilt.
That's all original wiring for the ECU. No problem there unless the wires are damaged. The plastic sheathing becomes very brittle and breaks off, he tried to cover the harness with tape.
Oil in the intake manifold could mean 2 things. Excessive crankcase pressure or a bad PCV valve. But the PCV valves rarely need replacement.
If it was the crankcase pressure could that cause misfiring?
Well yes, but I don't think so in your case. It is typically caused from blowby which can be indicated by low compression. Your compression readings show wear but not low enough to prevent proper functionality or cause misfires.
I am really stumped at this point i don’t know what else it could be. I’m gonna check the fuel pump and the cat as well. I don’t know if this could also be but maybe the crank sensor? When i bought the car the cat didn’t start until i added a new crank sensor. Could it have gone bad again?
