420A Random Misfire on all 4 cylinders
estuardowrld
128
17
Jun 11, 2023
Southgate, California
Welp. This is my final hail Mary since i got the car it’s been having misfiring issues every-time i take the car on the freeway. I’ve changed every part i can think of.
Cam sensor
Crank sensor
Fuel filter
Spark plugs gapped at .50
Wires x2
Ignition coil x2
98 Auto ecu
Egr delete
Only thing i haven’t touched is fuel pump and injectors. Everytime i go on the free way in 4th or 5th gear the check engine light flashes and the dreaded codes come out. I don’t know if it’s a possibility but the old owner had wired in the ecu. Please help
So i have the haynes manual and i started reading it and it has a page where if the engine is misfiring through driving speed range it has a checklist. Ige done everything but the fuel injectors and the vacuum leaks.
I had random misfire as well on my 98 gst spyder and it was injector 1..make sure u replace with OEM .. I found a used one n worked fine for me
everyone i haven’t updated the post because i got covid again. Anyways i took my injectors to be rebuilt and i bought complete new IAC and i swapped the crank shaft sensor again. But now my car does this like cut that sounds like it’s gonna die then the rpm’s climb back up.
Video didn't work
