ECMlink Questions from a newbie :)
Colinssweeney
11
Dec 30, 2021
Calgary, AB, Canada
Hey guys just hoping to get some insight on tuning.
I have a 91 eagle talon with a fully built block and 20g turbo, ecm link v3 with some other goodies but a STOCK transmission and drivetrain.
What’s a good launch limit for a stock trans? I really don’t want to have to put a new transfer case in.
What’s a safe rev limit, right now I have it set to 6750rpm. Can I go higher safely?
Also when I’m doing pulls and data logging everything cuts at 5500-6000 rpm I have 850 fic so fuel flow shouldn’t be an issue, someone told me it’s probably a fuel pump issue is this common?
Please understand that I’m 19 and this is my first DSM and my first project car.
Post a log of a pull so we can look at it.
7500 should be a safe RPM limit since that is about what a stock 4g motor is. A truly built motor can go 9000+. I pull mine 9200 but I built it and know how it is put together and with what.
You can see it on this log at the 520 second mark as an example.
Awe shit. :(
If you still have the 3 bolt rear end, I would recommend to upgrade to the 4 bolt rear end first before planning to raise the launch limit or making more power. Probably you would break it before breaking the transfer case. You won't regret it.
  • For sale Carbonetics Carbon Quarter glass
    Bnew Carbonetics Quarter glass
    • jabo97gst
  • Wanted 1g Wtb: Palm pilot w/ MMCD and cable
    I am doing an old school build with my 1G and am looking for this ancient hardware. Preferably...
    • Jeff D
