1G Pulling Engine Help
jdigitty
155
Aug 1, 2009
lakewood, Washington
Okay well I searched and didn't find the answer I need. I'm trying to pull the engine and then I get to the axles and there's no way they are coming off. Ive tried pb blaster for the last two days. So this is the my main issue can i pull the engine and leave the tranny and axles in?
little advice... when you put all the new stuff in, put a coat of grease around that nut and cotter pin. living up north is hell on the steel components. the grease will keep the salts and chemicals from reaching the the metal and causing this kind of damage. A cheap trick to help save your sanity next time you need to pull the axles or anything else for that matter.
