2G Pulling Engine
Turbo2g
5+ Year Contributor
278
54
Oct 13, 2017
Fallbrook, California
I need to pull the block on a 98 GST 5 speed to inspect after developing a rod knock. I am hoping to pull the engine alone as I need to be able to role the vehicle out of the shop once Im done. If the front components and balancer/harmonic damper are removed, can pressure plate clear the bell housing on the transmission?
From what I understand, on a 2g, 3 of 4 mounts connect to the transmission anyway, so would it be better to just leave all that connected and maneuver the engine? Not having to pull axles etc.
Step 1
With the vehicle on the ground in it's determined service spot, unbolt the upper ball joints from the spindles on the driver's and passengers side
Step 2
Raise the vehicle and place jack stands under the chassis in the proper place
Remove wheels and using a popper tool remove upper ball joint from the spindles, the spindle will now angle pretty far forward. It is wise to remove the caliper to gain extra clearance
With the added clearance from the spindles rotating forward you have enough room to successfully pop the axles out of the transmission. Oops drain oil first LOL
Unbolt the front trans mount and remove the crossember
Once the axles are popped out of the trans the rest is just unplugging wires and bolts
The car can still be a roller without the trans
The laziest way after popping the axles is to lower the car onto the engine with a dolley under the motor. Car will rest on the rotors, unbolt all the motor mounts and cross member, and then use the engine hoist to lift the chassis off the motor and trans
You are correct, on a 2g fwd the rear trans mount bolts the trans to the rear main sub frame, the front trans mount bolts the trans to the radiator cross member, and the third is the main trans mount on the top of the trans
To remove the rear mount use three long extensions on a 14mm socket going down by the throttle body to the cross member
Thanks for the detailed response, I haven't got to start on it yet, every time I go in on my day off I get suckered into working since I'm on flag rate and there money on the table. One of these days will be slow enough LOL.
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
