turbosax2
Moderator
- 4,483
- 677
- Nov 19, 2006
Mechanicsburg,
Pennsylvania
Is there any way you can fit the insert in? I mean, it's supposed to be a tight fit.
, see how the front one has more space for the rubber part?
Prothane's fit in this mount fine.
Does yours look like mine? Just fat rubber part , there are some pictures check.. Post your if you can .
Getting to the rear mount was a little harder than I thought it would be
By my best guess, the diameter of the Prothane insert is 65mm and the diameter of the metal ring inside the rear mount is 75mm. These are crude measurements because of how hard it was to get back there.
These were the best pictures I could get.
Yeah and by the way , did you use a press for the left and right ones?
I already posted how to fix this before. Take the old mount out, and just use the inserts. To get them to fit properly, you need to cut an intercooler pipe connector in half, and wrap the inserts in it. The coupler acts as a shim, and it pushes the mounts snuggly in place. I have had a car like this for a whole season with no problems.
Guys check out my pictures , the stock mount is huge , it wont go in any way. The other one that i bought looks better , so ill try my best.
