prothane mounts, now engine is unlevel.
sciondan
123
Oct 27, 2011
valley, Illinois
Like the title says, I installed a full set of prothane mounts in my fwd 5speed and now the engine is clearly not sitting level. I will post a pick later if need be but the transmission side sits up higher. Anyone else run into this? It's not hurting anything but is bugging me. Thinkin it has somthing to do with the trans mount bracket itself. All the mounts went in smoothly except the trans. It was a real pain to get the bolts to line up.
Not familiar with the FWD mounts, but if the hole is offset, you might have it upside down.
Having the same problem on my 91 awd, transmission side sits up higher. Can any one help with this? Do auto trans mounts sit up higher then a 5 speed.
Auto tranny mounts are different than the Manuals.
And to the OP: what do you mean not sitting "perfectly level?" I'm sure unless your car was wrecked previously, it is level no doubt.
Transmission side sits to high, I have the trans, firewall an driver side mounts connected and my hood wont close hits my DNP manifold.
