People with Prothane engine mounts...
destrux
85
Nov 27, 2002
Tamaqua, Pennsylvania
Anyone notice more gear whine/noise from the trans after installing these? Is that normal or is it just my trans? For a year now (since I installed the mounts) it's been whining fairly loud on light accel or any kind of decel and hasnt blown yet. I don't if that noise is normal and was always there and the harder mounts just make it audible or what...
what you said last is probably the case...since the mounts dont give much, you are noticing a lot more noise and vibration(at idle with the a/c on my keys jingled in the ignition). and if the noise/whine hasnt gotten worse and the tranny has been holding up fine in the past year, i wouldnt worry about it too much. just check your tranny fluid level to be sure, and that should be it.
