Prothane mounts ?
Status
Not open for further replies.
Evol krap
29
Mar 22, 2005
clementon, New Jersey
I was told if you replace all 4 mounts its alot of vibration...also will replacing all 4 hurt the trans as far ass no movement...also how do you get the rubber outta the left and right mounts...?
In my case I used hydraulic press machine to remove the old rubber with the metal frame from 3 mounts. After installation I was PLAMING myself :mad: but after using the car for about 1K mils the vibration reduced ... and I'm no longer worry about engine mounts LOL!
Christ... Did you even try searching?? I have personally posted in many threads that have extesivily explained the level of vibration, as well as a few different methods of installation. Here's a few; if they dont answer your questions, then continue searching....
http://www.dsmtuners.com/forums/showthread.php?t=183335&highlight=prothane+mounts
http://www.dsmtuners.com/forums/showthread.php?t=174597&highlight=prothane+mounts
http://www.dsmtuners.com/forums/showthread.php?t=167701&highlight=prothane+mounts
EDIT: You asked the same question a month ago! How many times do we need to answer it for you? -------> http://www.dsmtuners.com/forums/showthread.php?t=180169&highlight=prothane+mounts
Search and research before posting a thread.
Status
