Pros and cons of a turbo outlet?????
You mean a 3" o2 housing?
Nothing. You may even have worse performance because the exhaust will be going from a 3" pipe into a 2.25" stock exhaust (if it would even bolt up). That step down is really bad for flow.
Read through this.
Tech Guide: 2G 4G63t Upgrades - DSMtuners
If you have the exhaust to match a 3" O2 Housing with help spool up and flow, especally if upgrading from the restrictive stock housing.
When I upgraded to a 3" O2 Housing it helped my spool 1-200 rpms.
I have a 3" Downpipe and 3.5" Cat-Back.
Most true 3" O2 Housing will put you real close to the Alternator.
And most ' 3" ' Housings are really 2.75".
    • george bromwell
    • pma1123
    • Sdcryan1
