Products the DSM crowd would like to see made
Any pics of that license plate bracket, never seen it before.
Can someone PLEASE make me a 2g lower radiator hose out of aluminum or ss and put a bung on it for a water temp sensor.
Im curious to if any vendors are watching this, and atleast contimplating some of these ideas. Obviously, there needs to be enough actual demand to make it cost effective, but I am curious if any of the 100+ ideas have sparked anything.
Can any vendors that are condisering any of these products chime in!
I think I'm just gonna use this...
I think that the plastic license thingys still need a bracket to attch to, but we'll see
Less scratching of car paint and rust to collect behind the plate?
I'm in the process right now of exploring my options for the design and production of dsm specific harness bars. In about two months I'll have more time due to the karting season being over. I'll keep everyone updated. My goal is to keep the cost as low as possible on these guys while not cutting any corners. :thumb:
Am I the only one that sees no point to a 6spd tranny? 1st gear is already short enough and you have to shift right away the rest of the gears seem to be really good.
Maybe you guys aren't making enough power yet to notice.
I don't think a 6 speed would help any unless you're looking for a major overdrive 6th gear. These cars could use a taller gear for cruising on the interstate at 70-80mph. Maybe some people just want another gear instead of getting the taller 5th that is available?
I agree 1st gear is painfully short. I would love a taller 1st gear that is stronger than stock. The evo 3 3rd and 4th gear will get you tighter ratios if you want. Then slap on a taller 5th and you'd have the perfect transmission :D
CF parts
-Carbon fiber steering column gauge bezel
-Carbon fiber coil on Plug plates or kits
-Carbon Fiber Rear diffuser
-Carbon Mirror covers for a 2g like (apr makes for other cars)
Other
-Reasonably priced 2g FMIC kit w/ smooth tapered endtanks and short route piping thats not too much to ask is it??
-Bolt on 85mm + downpipe for 2gs
I think that most of us aren't thinking acceleration when they are suggesting a 6th gear. I just don't like being near 4500 RPMs when I am cruising at 90+ for hours on end. At half that I would still have plenty of power. Maybe its just cause I grew up with a Jeep that red lines at 5000, but I like to keep the revs lower.
Whatever happened to the 25% taller gear they used to make? Would anybody else be interested in one of these?
There's no reason to be going 90+, especially for hours on end.
If you want to be at a lower operating rpm just get the EVOIII 5th gear.
Yep, I would be interested in the 25% taller 5th gear, but some friends of mine tried looking for it and had no luck....
Edit: Well the Evo3 5th gears isn't that much taller either, it's like only 200-300 rpm difference...
I end up doing a lot of driving through the middle of no ware so yes, there is a reason to be going that fast for extended amounts of time. Also, I don't want to enter something like silverstate when that would mean even higher RPMs for a pretty long amount of time
10% isn't really that much. It seems like there are enough of us looking for one that some one would make one...
