ChristianEclipseAuto
5+ Year Contributor
- 142
- 9
- Apr 6, 2018
Roskilde,
Europe
Hi everyone,
I recently bought an ECU with ECMLink already installed, as I wanted to upgrade from my Black Box.
My car is the Japanese-spec version from late 1996.
After installing the ECU I purchased, the car keeps throwing an injector malfunction error for cylinder 2.
So far, I have replaced the resistor pack, swapped the injectors around, and reinstalled my original Black Box ECU, which works fine.
However, with the Black Box installed, the AFR fluctuates between 11.2 and 14.5 at idle, and I can hear the fuel pump (Walbro 255) changing speed slightly, going up and down.
I have had the ECU checked by an electronics specialist, who couldn't find anything obviously wrong with it. However, he suspects that the injector driver itself could be the issue.
I have also gone into ECMLink and tried activating and deactivating the individual injectors, and they all seem to respond correctly.
Does anyone have any suggestions as to what could be causing this issue?
Any help or suggestions would be greatly appreciated!
Thanks in advance!
Thanks in advance!
