ECMlink Another problem with Boost Control on ECMLink
polverari
5+ Year Contributor
100
15
Jan 29, 2018
São Paulo, South America
Hello!
I'm here creating another topic because I was able to solve the previous problem, however, I'm having a new problem.
In my last post, I was complaining that my wastegate was not opening and the turbine was under "infinite" pressure.
This issue has been resolved and the topic can be found here in this section. I removed the 0.025-inch restrictor and the wastegate started to open normally. I put the preload on it and now it always opens with 0.85 bar (12 psi).
The problem is I can not put more pressure on it. I go on the pressure control flap, I put 50% on all the columns of the third gear, I put 60%, 70%, 95% ... And it always comes with 0.85bar (12 psi).
So I thought the problem could be on the fuel solenoid (FPS). I took her and bought another model (I'll leave her image here)
The problem continued .. Even putting 95% on the table, the maximum pressure remains 0.85bar (12 psi). Anyone have any suggestions? I've done all the connections correctly, tested the aftermarket solenoid and the FPS, removed the 0.025-inch restrictor and I do not know what else it could be.
P.S - I do not have MAP sensor, so I'm not using the automatic correction system, just the "Duty Cycles".
Thanks to all who can help.
