ECMlink Boost Control With FUEL Solenoid (2G)
polverari
5+ Year Contributor
100
15
Jan 29, 2018
São Paulo, South America
Hello!
As I usually do: "I apologize for any mistakes, I'm Brazilian and I'm not fluent in English"
My problem:
I'm using FP 68HTA.
Previously, I was plugging my wastegate directly into the pressurizing of the car.
Wastegate opened with 1.1 bar.
So I talked to a friend who works with DSMLink and he suggested we use the original solenoid (BCS) to control the turbo pressure. The idea seemed good, since I only wanted to oscillate between 0.8 and 1.4 bar. (11 to 20 psi)
However, I discovered that my car was already without the BCS. To make matters worse, he also did not have the EGR solenoid. Only the fuel solenoid remained.
So I took the fuel solenoid (which, by the way, was not being used) and did the whole procedure with it (according to the ecmtuning site, it could also be used for this).
I mounted everything correctly, even with the 0.6mm (0.025 inch) restrictor. However, when I was accelerating, a lot of pressure was coming. (More than 2 bar (30 psi))
My friend said that the problem could be in the wastegate, since I was using it totally closed.
So, I followed a Youtube tutorial and put a certain 'pre-load' on it. I'll even leave here the link of the video I used:
After that, I went to test again and, even with the new wastegate regulation, there is still A LOT of pressure coming. I can not even tell you how much is coming because I have to stop accelerating when the pressure gauge starts to mark above 25psi for safety.
My friend's next orientation is to remove the 0.6mm (0.25 inch) restrictor because the wastegate is supposed to be too hard for it to be used.
I wonder if anyone has ever used the original solenoid (BCS) or used any of the other solenoids for this (EGR or Fuel).
Still, if anyone has any hints or opinions about what's going on, I'll thank them.
There are some pics, but here is the link of a video, maybe its better to see:
What is going on with all the clamps on the 3rd pic?
Did you visually verify that the internal wastegate is opening the flapper?
Just to confirm, you are using the Fuel Pressure Solenoid (FPS) instead of the factory/aftermarket Boost Control Solenoid (BCS) ?
Sounds like the fps is non functional, I'm not sure if they rest in an open or closed position. Since you were getting control before with it directly hooked to a boost source, that's where I'd start.
verify the solenoid operates, then verify you're actually getting proper signal, then check the wiring is good.
On the clamps: I had to use a few more to put the restrictor!
I did the test on wastegate before and yes, I'm using FPS instead of BCS.
I have now discovered the problem and will leave you registered for an answer here in case someone else has it!
I was able to solve the problem by removing the pressurizing restrictor (0.6mm). Probably the site ecmtuning.com recommends the placement because the wastegate of the original turbine is much more permissive than the wastegate of other turbines (like my 68HTA). Now, with the preload and without the restrictor, the wastegate opens with 0.85, allowing FPS control. Thank you for your help! If anyone wants to question something about what I've done, feel free to
  • Wanted 2ga side markers
    Looking for 2ga side markers
    • Rohitter7878
  • For sale 2g 2G Fwd Thermal Research exhaust
    2g Fwd Thermal Research cat back exhaust
    • ari2gdsm
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
