Power Steering Help...
Ramphix
58
Mar 10, 2008
Pickens, South Carolina
I have got a question. I was driving down the road today and my power steering seems to get real hard at a turn and won't go back to normal. I checked my power steering fluid and it seemed low so I filled it but no help. It is hard as hell to steer now though. What could this be? I never heard a bad noise or anything.
did you check the belt? Check the teeth if they are cracked or missing then its probably time for a new belt. this could cause slipping and will affect you steering. you should change all the accessory belts while your in that area.
I found out Power Steering belt fell off... any picture tutorials on replacing it?
do you have a copy of the manuals? a chiltons or haynes will have pictures and steps on how to perform the belt change. make sure you change the other belts down there too as they might be worn
Yes when I went down to Auto Zone I grabbed a copy of Haynes Repair Manual for 1995 - 2001 Eagle Talon / Eclipse... If you have this manual could you give me a page number I could look on? Yes I also bought the alternator belt since it looked worn to hell...
I don't know the page number because I have the manual for the 1g only. Look in the index at the beginning of the book. It should have a section on replacing belts. It is usually under the engine section.
