Possible bad Coil Pack, car dies when I rev
ZDA1728
95
Dec 13, 2012
Chicago, Illinois
My car idles fine but but the revs drop to close to 0 and the car dies if I touch the throttle. New plug wires, plugs, and ECU. Im just wondering what the problem could be, pretty stumped. Thanks
Plugs wouldn't do this. Why I mentioned filter is that the rail doesn't have enough fuel pressure to keep the injectors filled - why he can idle okey, but once the pedal is mashed, the low pressure in the rail isn't enough for the sudden demand from the injectors and the motor is suddenly starved for fuel and dies.
He also could have a bad power resistor (module)...did he check this one out since he did all the rest of the ignition?
Im haveing kind of the same problem motor finally got put back togegher, drove around the block fine and after it sat for a vouple days i touch the gas abd it dies instantly
ECT (engine coolant temperature) sensor could cause this as most cars I'm assuming need to know the temperature of the coolant and compare it to the ambient air temperature to run correctly. My 91 saturn had the same issue when the ECT crapped the bed. It would idle ok, but as soon as I stepped on the gas it would stumble and almost die. Might not be the case for DSM's, but just throwing it out there.
thanks for the tip i finally got her to run but she starts then dies like 3 times and then i fire it and it will finally stay running i dont get it
Got a new fuel filter putting n tomorrow hope that does the trick[DOUBLEPOST=1407973277][/DOUBLEPOST]i dont mean to take over a thread but new fuel filter didnt fix mu problem, should i move on to fuel pump?
please help
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
  • Wanted 2ga side markers
    Looking for 2ga side markers
    • Rohitter7878
  • For sale 2g 2G Fwd Thermal Research exhaust
    2g Fwd Thermal Research cat back exhaust
    • ari2gdsm
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
