possibilities of the ported big 16g
Malero5
86
May 14, 2005
eagle, Idaho
I am going with a full engine rebuild and I am putting in 264 HKS cams/gears. With a FMIC, MAFT blowthrough, 3 inch turbo back exhaust, 255 Fuel pump/AFPR, good 02 housing, and on pump gas. Can I get anyhitng over 300 Whp on a 16g? Its ona FWD that will eventually have a dsmlink setup.
Do I need new injectors before the turbo is maxed out?
I cant tell you how much power you can make on it but I can tell you, the 450cc injectors will be maxed out pretty quickly. When I had my b16g, I maxxed out my 550's. That was with comp cams, fmic, 2g mas, and 21psi on pump gas. I would suggest that you run at least a 550cc injector with that setup, and nothing smaller.
