1G Ported Big 16g
Riceboy
55
Jan 25, 2004
LaPorte, Indiana
Ok i found a Big 16g ported for $300 with 2000 miles..good deal? and is this a good turbo 2 go with i hav an AWD 1992 talon nothing done yet but what supporting mods would b best 2 go with if i got this turbo? im not gonna b doin anything with it until i have all the supporting mods. i want all around boost but i want a hard long pull. and how much power can u usually get out of the 16g?and also would it b good 2 go with this or wait and get a T28 i heard they pull hard bottom end?
Thnx 4 any help guys
Terry :dsm:
a simple search would have given you all of these answers. ill touch base on some of them for you. the deal on your turbo seems to be good. check it over before buying it and look for anything obvious like cracks in the housing, check the blades and shaft play. as far as supporting mods your going to need a fuel pump, 190 should be able to get you by for now and some injectors. id suggest skipping 550's and going to something like 650's. you may need a FPR. you will need some sort of fuel controller. plan ahead on how you want to have your whole set up. DSM link? SAFC? what do you want to do? a nice intercooler/pipes/blow off vavle will help. you should be ok w/the 1g bov. your gonna need some sort of boost controller. MBC or EBC? your choice.. personally id rather have a ported big 16g over a t-28 but thats my preference. search all of this, its been covered numerous times.
K i will search it but 1 quik question will a 255 lph fuel pump and 880cc injectors b 2 biig?
Thnx man
Terry :dsm:
Thnx man
Terry :dsm:
255 will be ok w/a fpr and 880's are too big for what your going with
