planning on upgrading my stock turbo
sharky559
191
Mar 6, 2010
Sanger, California
ok bros im stuck i wana upgrade my stock turbo but dont know which one. any help would be good.
mods are: Dsmlink v3,255 walbrp pump, afpr, engine pro valves.
That would depend on hp goals. I have a 14b in my car, stock fuel system, a few little mods. I like it. Its quicker then it was, but its def not a BIG 16g running 20 psi.
I agree, you need to decide what your goals are for the car itself including numbers. On your 2G even a 14b turbo from a 1G is an upgrade over the stock T25. Depending on how much money you want to put into the upgrade including correct supporting mods, A MHI turbo (either 14b or 16g) may be perfect for what you already have done....Just my opinion. Hope that helps
I agree with the people above, before you can make an educated guess on which turbo you would like to upgrade too, or any modification for that matter, you need to set a goal. Either a horse power/Torque number or to a specific type of motor sport (Drag, Auto X, ect.), or just to have fun.
There are several good sources of information for this topic. One of which is the Tech section of this site. It is located along the top bar, Tech. If you click on upgrade paths there are sections for Drag racing, Auto Cross, and general upgrade paths. There is also a list of links at the bottom of the page that are completely indispensable.
Hope this helps. Good luck and pick a goal before you purchase. It will make your life 100% easier!
