420A Piston Rod Bolt Torque Specs? Stock 420a Pistons
ChristianP2506
May 18, 2023
Brownsville, Texas
Hello, does anyone know the torque specs for the piston rod bolts in a stock 420a piston? Do you have to go in a certain torque amount order? Can someone please provide them?
And if you'd be so kind provide torque specs for the oil pan 10mm bolts...
Torque would affect bearing clearance, etc etc. So you should be careful about that.
Please refer the pdf manuals below.
