420A Tuning a stock 420a question.
Ryan Pappalau
Apr 6, 2020
Ballston Spa, New York
New to the car community and am having some troubles. I have a pretty much stock 420a on a 97 rs. It came with stage 2 Brian crower cams in the box still and since I work as a tech I’m able to install them. But what I have no clue how to do is tune the car. Do I need a stand alone? Can I reprogram and tune the stock ecu? I have the timing tag for the cams but still no idea why I’m going to do for a tune. And honestly? Do I even need one? Probably.
You can't tune the stock ECU. With just a set of cams, you probably won't have to make any changes anyways. What are your long term plans for the car?
A wideband 02 sensor would be a good investment. That will tell you if you need to add additional fueling after the cams.
FWIW the research I did on this topic has been the following:
Upgrade to wideband with a megasquirt system installed and then you can start to tune the 420a.
Withought the megasquirt you are only able to look at your fuel trims and install the proper mods like bigger pump or bigger fuel injectors.
I havent done any of this myself and I'm sure things get a lot more complicated. And iirc the bc stage 2 cams dont require anything to run properly, maybe slightly bigger injectors if your fuel trims is a little lean?
So you’re saying I could likely install the stage 2 cams and not need a tune? And plans, I would like to think of a turbo later down the road. But for now, the cams came with it when I bought it. Just never installed. So since their there I may as well put them in. I just didn’t know if I would need a tune.
Sorry I also forgot to mention you will need a spring and retainer kit as well for the stage 2. Check the part number on the cams, did it come with springs and what not? Dont want your stock spring to break, they are most likely tired and worn out. Here is a link for you.
https://briancrower.com/makes/mitsubishi/420a.shtml
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
  • For sale 2g 2G OEM Cargo Net
    2G OEM Cargo Net $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 2g 2G Auto Shifter Cable ( GSX/GST )
    2G Auto Shifter Cable $45 + shipping & paypal fees* GSX/GSTYou must be registered to see...
