99gst_racer
Moderator
- 12,010
- 1,706
- Apr 5, 2003
Coloma,
Michigan
You need to replace those rings. .031 is a huge gap for a top ring, and your 2nd should be looser, not tighter than the top. The loosest gap I would probably recommend would be what sb7775 stated above. Anymore gap than that and you will have low compression and alot of blow by.china said:quick question--> me and a friend just put my shortblock together and i gaped the top to 31 thousands, and the bottom to about 27 thousands.. i was told by the machine shop that its probally not going to hurt it. . "is this true?
block is 30 over. 6 bolt
weisco coated pistions
eagle rods
knife edge crank
no ballance shaft.
everything balanced
Is this motor going to see very high boost?
When I get a little more progress ill post pics of my build.
