Myristica
- 58
- 0
- Jun 26, 2011
Antwerp,
Europe
Hi all,
with all the problems I'm having, I'm thinking to just do a short block revision..
I have very little idea of all the parts that I will need... can you advise me on this?
- bore and flatten the block in a shop (bore size?)
- crankshaft (use the stock one I have? 6 bolt)
- beam rods
- pistons
- main caps
- main rod bearings
- oilpump
- waterpump
- balance shaft elimination
- timing belt + pulleys
There are so many brands to choose from. When I'm ready with the build of my car I want to be somewhere in the 350-400pk range. So I don't need to be buying expensive premium stuff that can handle 600pk+.
I already had a head revision some 6 months ago.
All advice is really appreciated.
Thank you!
- beam rods
- pistons
- main caps
- main rod bearings
- oilpump
- waterpump
Thank you!
