2g head on 6 bolt short block?
Kokomoguy30
35
Mar 8, 2006
malinta, Ohio
Can a 2g head be installed on a 6 bolt block? Or what mods need to be made so that it can be ? All help Appricated.
I'm also thinking about that swap. Remember you will need a cam angle sensor from a 93-94 1g. You need to shave the timing belt side motor mount bracket. You will use 6 bolt timing parts when you do the swap. Good luck:thumb:
