1990bcgsx
- 2
- Oct 3, 2017
Seattle,
Washington
1990 GSX (http://puu.sh/xPq5n/d6ae9700a6.jpg)
ECMLink
HX35
Huge FMIC (http://puu.sh/xPq3l/018447470d.jpg)
FIC 1650's
Stock Radiator (http://puu.sh/xPq9t/97500021e8.jpg)
Car is a new build, so this issue started as soon as I got it running.
Motor came out of another car that sometimes had cooling issues, but didn't really drive around a ton anyhow.
So, car can drive around a while, and then starts overheating (215+).... if it is cool outside, the car can drive for hundreds of miles on the freeway, but if you are in slow traffic, or if it is hot out, car will overheat quickly.
Here's what I have checked..
I'm not sure that that piston can cause the thing to overheat like this.... so I'm looking for advice of what to go after next... I'm figuring I'll check the water pump while I'm fixing the piston... but.... any other ideas?
Driving me nuts...
Thanks!
ECMLink
HX35
FIC 1650's
- Thermostat (New, 180 degree)
- Radiator Cap (New)
- Put 2 big fans on it, and wired them to stay on all the time. (confirmed they are pulling in right direction)
- Put 2 more big fans on it in pusher configuration. (confirmed pushing in right direction)
- Checked Radiator to see if plugged (it isn't)
- Coolant Test to check if exhaust gasses were making it into coolant (they weren't)
- Pulled head to check head gasket (HG looks OK, piston #2 has detonation - see pic (http://puu.sh/xPpLp/315ff34969.jpg))
Driving me nuts...
Thanks!
So I'll probably be enjoying overheating problems soon here too.
