oil to water cooled turbo?
99cliprs
107
3
Jul 16, 2006
VA, Virginia
Im in the process of getting parts to rebuild my turbo, I have a PTE 5031 thats oil cooled and found a garrett oil/water cooled chra that looks identical but its missing the 3 holes to bolt down the 360 thrust, but thats it. Is it possible for me to switch to a water cooled chra or is it even neccesarry?The Garrett water cooled center housing part # is 430027-0050 ill post pics so you can see what im talking about thanks
http://www.dsmtuners.com/forums/newbie-forum/315128-turbine-wheels.html
Why did you buy a new center housing, were the journals shot? Garrett center housings are rather durable; I've actually never had to replace one because of the journals being worn too much. A new set of journal bearings should fix your up/down play issue.
PTE and some Turbonetics center housings are drilled for a bolt-down thrust plate, while most Garretts that I've seen simply use the thrust plate retainer that normally holds the 270* thrust plates down. This would explain why your new center housing isn't drilled if it's a Garrett part.
no I didnt buy it yet, It was just a thought maybe to improve the life of my turbo....
I just got in new journal bearings and snap rings today so shaft play is gone. Im still looking for a kit or individual parts. I found "T3 / T4 Turbo Stagger Gap Turbine Shaft Seal" is that any good? another kit I found was this one on ebay just to replace a couple screws here and there but im not sure of the quality it has everything else I need, take a look and tell me what you think....
eBay Motors: Turbo Rebuild Kit Garrett T3 T4 T04B 360 degree Thrust (item 220315506384 end time Nov-27-08 01:55:41 PST)
