oil temperature sensor
Mexjzl
Apr 15, 2022
Santa Fe, New Mexico
I have a 1998 eclipse gst I want install a oil temperature gauge where do i put the sensor at ?????
At wherever you want to check the temp. If you don't have any available port, you have to make one. People use an oil drain plug with a 1/8NPT port like the one in the link below. I personally prefer to read it at post oil cooler if possible, since that's the actual oil temp that goes into the main oil gallery. If you have an external oil cooler, it would be easier to install the sensor.
