2G Oil leak somewhere!
SEVEN2NiNE
Jan 26, 2013
Coatesville, Pennsylvania
So my 1997 GST has what seems to be a pretty bad oil leak somewhere I can't find it. It looks as if the oil turbo feed line is shot but I'm not sure. It could also be something minor and since oil was on the timing belt it slinged it everywhere. I have searched on the forums for my question but have not found the correct response. If you can help I would greatly appreciate it.
Ok, does that turbo oil line look like its bent to you? Or is it supposed to be angled?
Degrease first, much easier to see then. Looks like it is running down from cam seals, valve cover gasket or front timing cover.
Thanks for your input guys, it's really appreciated. I'm going to take it to the shop today and see what yet say and go from there.
So my cam gear is cracked causing it to wobble and my seal is shot. Anybody have any cam gears for cheap? Lol starfawes gets plus rep
