Oil leak
byrdman4185
Aug 17, 2009
tucson, Arizona
so i have a 96 gst. i had noticed that the valve cover bolts where loose so i tightened them up. then the next day at work i started blowing a bunch of white smoke out and blowing oil out the oil fill cap. so i went and got a new PVC valve and that seem to have fixed the white smoke problem but it hasn't fixed the oil blowing out of the filler cap. now i have done a compression test and everything is good. no water in the oil. nothing like that. so any ideas on the oil coming out of the filler cap????
After a while the rubber seal under the edge of the oil filler cap gets hard and doesn't seal anymore. I think you can get a new seal from the dealer. Or a new oil cap with a new seal will work too. I had the same problem, and I'd end up with a puddle of oil in the valve cover where the plug wires are. Got a new filler cap (mine was chipped anyway) and it fixed the problem. Good luck.
