420A Oil leak
Cfrakes
63
Jun 6, 2021
Idaho
Got a 1999 eclipse RS and I got a oil leak coming from above the oil filter and it's not the valve cover any thoughts? Also I did up my timing and crank seal and after doing that I got two leaks coming from my oil pan any idea how the heck that happened? Thanks
Oil filter housing o-ring could be leaking but that's rare. Check your oil pressure sensor on the backside of the block. Those are usually leaky if aged. Also if you suddenly had a new leak after replacing any seal then I would start with double checking it.
