9 T GSX
- 203
- 38
- Jan 19, 2008
St.Pete,
Florida
Need a little clarification in getting this modification completed, the harness has a connector for a AEM infinity instead of the stock ecu connectors.
As some know the 90's are a bit different than the 91+ when it comes to finding the correct connectors for this install. Such as 1990 car uses an 8-pin, 7-wire connector (C-67) and later manual transmission 1G cars have a 14-pin connector, instead of a 14 and 18 pin setup on the 91+ cars. I have been trying to figure this out looking at diagrams but I don't a 1990 specific electrical manual only a 91+. I think I'm on the right path,if you could take a look at the list below to confirm this would be great, as you can see I found a good amount of the wires on the C-67 connector but there are no other white connectors in this area just radio,ecu,MPI connectors.
Resources that has helped so far:
First question: What/where is the other connector I need to find to install the other wires I have left?
The below is the pin-out for Connector C-67 for various 1990 models.
1 -M/T - NONE
(A/T ONLY - YW, yellow with white, Power/Economy Change Over Switch pin 1 to TCU pin 9)
2 -M/T - RB, red with black, magnetic clutch relay pin 2 to ECU pin 65/ #4 on OHM Harness
3 -M/T - RB, red with black, fuse 19 to ECU pin 103 for battery back-up/ #5 on OHM Harness
4 -M/T - 2.0L Turbo ONLY - BR, black with red, Boost Gauge (gauge cluster pin 6) to ECU pin 3/ #9 on OHM Harness
5 -M/T - LR, blue with red, fuse 3 to Power Window Relay pin 4 / #10 on OHM Harness
(A/T - RB, red with black, Magnetic Clutch Relay pin 2 to ECU pin 65)
6 -M/T - Y, yellow, Self Diagnosis Check Connector pin 1 to ECU pin 1/ #11 on OHM Harness
7 - M/T ONLY - W, white, Self Diagnosis Check Connector pin 10 to ECU pin 2/ #12 on OHM Harness
8 -M/T - RG, red with green, check engine light to ECU pin 64/ #13 on OHM Harness
This is the OHM instructions:
There should be 2 white connectors on your old 91+ 1G harness, one is a 14 way the other is a 18 pin, those need to be deppined and transferred to the new harness, no need to strip or cut any wires, just swap the connector following the numbers on them going from left to right on the new harness.
1. Empty
2. Brown ECU 19 TPS: Needs a Home
3. Empty
4. Black/White ECU 65 A/C Clutch Relay (can be used for other input when A/C not used) Found
5. Blue/Red ECU 103# Battery backup constant 12v (90 Used) Found
6. Empty
7. Black ECU 101 Ground to chassis: Needs a Home
8. Red ECU 101 ABS output (can be used as other input when no ABS used): Needs a Home
9. Yellow/Black ECU #3 Turbo boost gauge output Found
10. Blue (power window Relay) (90 Used) Found
11. Yellow ECU 1 Self diagnostic output (90 Used) Found
12. White ECU 2 Data transfer (90 used) Found
13. Green/ Red ECU 64 check engine light output (90 Used) Found
14. Green ECU 14 idle switch; Needs a Home
1. White (wiper): Needs a Home
2. Blue (wiper): Needs a Home
3. Empty
4. Empty
5. Tach signal power transistor: Needs a Home
6. Empty
7. Empty
8. Empty
9. Empty
10. Red (wiper): Needs a Home
11. Blue/white (wiper): Needs a Home
12. Empty
13. Yellow (reverse switch connector): Needs a Home
14. Orange (reverse switch connector): Needs a Home
15. Orange (coolant gauge): Needs a Home
16. Empty
17. Empty
18. Empty
That's all for now trying to keep the post nice and simple, Planning to do a how to with video as I go thru this so to help others in the future
1 -M/T - NONE
1. Empty
3. Empty
6. Empty
3. Empty
4. Empty
6. Empty
7. Empty
8. Empty
9. Empty
12. Empty
16. Empty
17. Empty
18. Empty
, I was unsure about a few of the pins and what component they went too but your post helped me confirm I had a few wrong.
