2G Oem or Felpro Valve Cover Gasket
Yamahaulin
695
12
Jan 30, 2010
Bowling Green, Kentucky
Is the oem valve cover gasket any better than the felpro gasket? Price is double, what do you guys think?
Ivw never had a leak with my Felpro vc gasket. Actually pulled the vc to replace lifters and just wiped the head surface and gasket surface with acetone and tightened the bolts from the inside out in four stages and still no leaks for about two years now. Dont ever use the cheap ones that come in the Ebay engine kits though, theyre made of inferior rubber compounds and get hard and leak fairly quickly. Most people with leaks are just not installing it correctly.
I used a cheap valvegrind kit from ebay and the crap V/c gasket leaked right away. It was just too small. Went to felpro gasket set and have had no problems since.
If not OE, then Felpro (IMO) is the next best option
I've been using the felpro gasket for 30,000 miles with no leaks.
But I can't stress enough get a torque wrench for inch pounds. Preferably one where the target torque value is in the middle of the torque wrench's range so it will be the most accurate.
If you torque it too hard you will crack your valve cover or strip shit. If you don't torque it enough you will have a huge f***ing boost leak.
If you torque it too hard you will crack your valve cover or strip sh**. If you don't torque it enough you will have a huge f***ing boost leak.
If your valve cover is a "boost leak", you have greater problems than the VC gasket and it's torque value...
