2G Odd engine surging problem when warm
Tyler Davis
5+ Year Contributor
137
36
Feb 18, 2019
Kenosha, Wisconsin
Hey guys, my car has been having this weird problem where when I am accelerating or holding the throttle in the 1500-2500 rpm range it starts to surge and jerk.it does not happen for the first 15 mins of driving but after 15 mins it does it consistently I’ve tried cleaning my IAC, changing injectors, changing my MAF, boost leak tested it. Has anyone else had this issue? It’s a DSM so I would assume so LOL
Thanks
I would check the fuel pump, the fuel pressure regulator and all wiring/connections for MAF.
I don't know if this helps but here is my experiences.
I had an issue before that when the engine was cold ran fine but after 10-15 min like after the engine got the normal operating temp, the car started to act very weird. It was a bad fuel pump. The pump was working fine when cold but after 10-15 min pump went hot and stopped working as it should. Just replaced with a new and the issue was solved. And this is not with a dsm, with a motorcycle, it also had a very similar issue that if the engine was cold it ran fine but after the engine got hot the engine hardly revved up, like bogging. It was a bad fuel pressure regulator.
Thanks I’ll have to try that
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
