kmoore
- 1,241
- 13
- Mar 8, 2006
St, Louis,
Missouri
Hey guys i got some questions concerning boost leak tests that i did. This might be kind of long so please hear me out and i could use any and all help.
About a week ago i got my uicp's and greddy type rs BOV from dejon. Well, i noticed that dejon gave me too big of a coupler (2 1/2") for my upper intercooler pipes so i called him up and asked if he could ship me the right one (2 1/4"). He said sure and he said he would ship me one right away. Well, i used the 2 1/2" uicp coupler for the time being until the right size one showed up. The 2 1/2" was a little big but i tightened it down really tight and made it work. So i got everything tightened down and did a boost leak test with the big coupler and the test showed that i had a boost leak by my throttle body. On my boost gauge during the test showed that i was pressurizing the system to 12 psi which was what i wanted. Got the leak fixed and took it out for a spin. It pulled really hard and i like both products a lot. Then, about 3 days later i got the right size coupler (2 1/4") from dejon. I put the right size coupler on and took the big coupler off. When i put the new coupler on i took off the pipe connected to the throttle body. I then did a boost leak test with the new coupler on and now i can't pressurize the system at all. I had my dad watch my boost gauge while i was trying to pressurize the system and he said that the needle didn't even move at all. I wanted to still see that the boost gauge was working, so i turned on the car and it IS still working. So it's not my boost gauge. So then, i purposely on bolted my BOV a little bit so that i could see if the pipes were getting pressurized. I did another boost leak test with the BOV un-bolted and air was coming out of the flange. So all the pipes up to my BOV are getting pressurized. I bolted the BOV back down and did another one and i noticed that air is coming out of my MAS (that big black box in between my filter and intake pipe). It is coming out of the smaller box inside of the MAS on the right side. Is air supposed to come out of there when doing a boost leak test? Should i block that off? Why can't i pressurize my entire system? What do you think is going on? Please help me out i could really use it. Thanks in advance and sorry for the long post.
! I dont get it. You said you had your boost leak tester directly on the turbo inlet, if thats the case then there is no way you have the intake hooked up and there is no way air can be leaking from the maf or anything on the intake since its not connected., Right?
joking of course. The answer is "no", this is why everyone is so confused, how can an electrical plug leak air? I even tried to confirm this with you on page one.
