1G No start, power but no starter clicking
Mitsu-MattGSX
3
Oct 30, 2017
Pittsburgh, Pennsylvania
I recently replaced my clutch master cylinder, line, and slave cylinder and I removed the battery for some access. When time came to start the car back up I have power but no sounds of the starter engaging. When I tried jumping it I made a rookie mistake and put the leads on the live car first and there was some sparkage. I checked my starter relay which looks ok. Then I checked to make sure my clutch safety switch was connected which it was. I then deduced it must be the starter itself. So I just finished removing the starter itself. The ground to the trans looks ok. The starter itself looks acceptable, I am going to clean up the connections. But I then noticed from the wiring harness that goes to the starter that it branches off very close to the starter. That then leads to a connection on the trans, which I've noticed is terrible. It's melted for one and it will not clip in place due to this. And secondly there's a lot of electrical tape poorly wrapped around the female end of the connection. Could this be the source of my issue?
Take that electrical tape off and check for diconnects. Also there should be a small wire with a black clip on the end that slides over that small tab on the starter. If that's not connected it won't work.
That small wire with black clip is fine, I removed it when I took out the starter
It very well could be your problem, I have ran into the problem of lines having corrosion where you can’t see it on the terminal but it goes through the center of the bundle of wires causing a poor if not bad connection. Double check at various points of the ground and hot wires for corrosion in the bundles of wires.. I’ve found it to be more of a problem on larger gauge wires than smaller wires.
Just ran into this problem lastnight with a buddies GSX, hit the starter with a hammer and GOOD to go.
Also, the two little relays on the passenger side kick panel. Those are often the culprit of no start.
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
  • For sale 2g 2G OEM Cargo Net
    2G OEM Cargo Net $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 2g 2G Auto Shifter Cable ( GSX/GST )
    2G Auto Shifter Cable $45 + shipping & paypal fees* GSX/GSTYou must be registered to see...
