No accesories, Electrical issue
dteaton41
Nov 23, 2007
leesburg, Alabama
I have owned my 1997 gst for a few years, rebuilt the engine, blew out a trans etc. And had alot of fun smoking v8's... But for the last few months i have had an intermittent problem with losing all my electrical accesories inside the car, i would slip my foot off the rest and kick the fuse panel and they would come back on, this occured several times until today the kick didnt help. I checked my 12 volts coming and it's fine nothing coming out though, i replaced my relays to now avail,. When i would jiggle the box you could hear it try to come back on but nothing. Im positive its somwhere close to the fusebox, I need help! Will a n/t fusebox fit? What is the module looking thing behind the box? Has this ever happened to anyone before? Thank you very much, I have found out almost every thing I know about dsms from these forums so much apprecation.
like nothing running from the fuse box inside the car works, I unhooked the entire fusebox with the car running the shut it off and started it agian. I also just put the box back in and if i sqweeze the module behind the box i get them back. does anyone know what thats called?
yea that etacs ecu is definetly what it is, I have called mitsu and it's 200 dollars and no luck at the local yards, does ne one have one? I would also like the keyless remote 4 it too. Thanks again
